mercruiser 4cyl
serrato
I just bought a 1987 boat with 4cyl Mercruiser engine. I think its a 3.7 alpha one engine. Im not getting any spark. Im getting 10 volts on the + side of coil and then about 6volts when cranking. The boat has been sitting for 2 yrs. could the condensor and points be the problem? The boat was left outside with out covering. any suggestions.. victor
Re: mercruiser 4cyl
Ayuh,....... Do a Tune Up,+ maybe it'll Start.....
Aatcman
At-Sea-Man
Re: mercruiser 4cyl
Sounds like the points to me. Replace the condensor and points as a set.
Hope this helps :)
roadrash
Re: mercruiser 4cyl
I believe you have the same engine and problem i had. look at my post, should be helpfull
Reel Poor
Re: mercruiser 4cyl
Six volts at the coil when cranking sounds low. Check the wire from terminal D on the starter solenoid to the positive side of the ignition coil. This wire should supply battery voltage to the coil while cranking. What is the battery voltage while cranking ? (your volt meter on Batt + terminal and Batt - termnial)
serrato
Re: mercruiser 4cyl
Terminal D has no wire. I do however have a wire from a solenoid mounted near the starter that looks to be the same color as the one on the coil. It reads 6 volts when tested.
Does anyone happen to know what the resistance (ohms) should read on the coil. I want to know if this is a good way to test the coil. thanks....
Reel Poor
Re: mercruiser 4cyl
To prove if this may be a problem you can run a jumper wire from the battery positive terminal to the coil positive terminal and see if the engine will start.
BTW.....Did you check the battery voltage while cranking ?
serrato
Re: mercruiser 4cyl
I tried jumping the coil and still no spark. When cranking over, im getting about 11 volts. Could I have a 6volt system or some kind of resistor that reduces my voltage/
Re: mercruiser 4cyl
Nope,..... 6 volts is Too Low, Even With the Resistor,......
And,.... When Starting,.....
The Wire from the Starter that RP showed you,...
By-Passes the resistor,+ sends the Full 12 Volts to the Coil to Start it.....
