Starting battery minimum requirements?
pman7
I've got a 71 Merc500 and I'd like to get a starting battery and use my deep cycle for only trolling and assessories. I have a tendancy to sometimes almost deplete my deep cycle by trolling.
Unless it's a foolish idea I'd like to keep my starting battery small. Would a garden tractor variety battery be sufficient, even on cold days?
What would be the minimum coldcranking amps I should use?
tashasdaddy
Re: Starting battery minimum requirements?
as hard as a inline merc can be to start in the cold, i think a 650CC is minimum. i use a 1150 CCA as i like to have the extra umph. we use to use a battery that was interchangable with the tow vehicle
LubeDude
I understand what you are trying to accomplish, but the extra weight of a good high cranking amp battery will assure you of a good starting engine. I never just buy the minimum battery for any or my vehicles, be it cars, trucks or boats.
pman7
So much for that thought.
Advice taken.
Thanks
tashasdaddy
now you got the idea, ever try to pull start that beast. as a teenager we use to rope start a 115 Johnson.
pman7
I've never had to pull start it yet (knock on wood). I've only owned it about 7 months. It's got the rope hidden under the cowling and I probably should get a new one. The rope doesn't look like it's ever been used but it just might be the original. I'd better take it out and check it.
I redid the wiring harness inside while installing a tach. So far it runs like a dream, starts up very easily, idles at about 780 and WOT is about 5300.
Thus far, Murphy's Law does not reside in my boat. :)
