Re: Merc 650 flywheel play?
I'd be more concerned if you had a lot of side-to-side play in the flywheel rather than up-down.
And if you can hear the Gnashing and Thrashing of the engine's innards from, say, 10 feet away with all the covers in place, well.............:%
How's it sound when you're out in the water; idling in gear, or underway at speed??
If it's not making your ears ring or passengers cringe, maybe it's not so bad.
A compression check would give you an indication of the health of the engine's internals; if you see drastically low readings in a couple of cylinders maybe a problem. But you say it's running OK, so I wouldn't expect it's too messed-up inside.
Robby, better get buzy on that boat, it's supposed to be 70 Friday!!!!! Too bad it's not going to stay that way for a while.
