OttawaAquaBoy
Thread starter- Joined
- Aug 15, 2005
- 29
Hi all,
Late last summer I posted about my milky oil problem in my 1987 3.0L 140 Mercruiser. I got a lot of reassuring advice that due to underuse it may have been caused by condensation. I changed the oil and filter, ran it hard and checked the oil again.....still milky. I changed the oil one last time while winterizing so it hasn't been stored with milky oil. A friend has suggested that I may need to replace the headgasket due to obvious rust stains below that point (not sure how to post images). While I have the head off I will send it for cleaning and adjusting. Are there any other things I should do while the head is off? Are there any other seals that should be replaced. The oil pan is tight and water has never reached it so I'm confident that isn't the souce of the water. Could the rust from the head gasket down be caused by anything else? The boat runs like a top, I need to find the source of the water and fix it before the boating season starts up here. Any suggestions would be very much appreciated.
