Stream Dancer
Thread starter- Joined
- Mar 18, 2007
- 1
It works! It works!
Years ago, I destroyed my back doing enders and pop-ups in kayaks. I had to switch to canoes with trolling motors but that was clumsy and didn't work in shallow water. I looked for alternates but none really worked, so I began designing and building. I'm in the prototype stage but I now have something that looks like an off-spring of a drift boat and a kayak. It has an electric motor attached to 30" long screw drives hidden under each side of the hull. A deep cycle battery is concealed in the a compartment out of sight. Two foot switches control the motors. While holding a rod & reel, you merely push forward on your feet to propel forward at 8 mph. Pull back on your heels and you're backing up. Push on one while pulling back on the other, you'll be spinning like a top. That does, however, make the fish dizzy!
Please check it out at www.streamdancer.com The site and boat are a bit rough, but I need comments and suggestions before going further.
You help is greatly appreciated,
Stream Dancer
Stream Dancer
