So it wont crank at all?
From your description, I would suspect you may have done lower end damage....
Possibly......
How do you know that you are not getting spark?
Did you check for voltage at the coil + terminal with the key in thr 'run' position?
Does the starter sound like it wants to crank but won't?
I guess where I'm going with this is I doubt that you created an electrical problem when you ran over the rope......
If the starter sounds like it wants to do something but won't, I would pull thre drive & see if it will crank then....
The other possibility is hydrolock......
To check for that, pull the plugs & see if you can turn it over by hand using a suitable socket at the pulley on the harmonic balancer & turning in the direction of normal rotation.....
If you can & no water comes out, then it is time to trouble shoot the starter & ign system....If it won't turn, the drive will have to come off & repeat the step above......
