The new SX series SmartTabs
KaGee
What do you all think about them as opposed to the original? Naughty John, your input?
Tail_Gunner
Re: The new SX series SmartTabs
You have to be kidding me i was just there, and there black to..........might be just what i need to put some Whoop A@# on Boomer ............:
http://www.nauticusinc.com/smart_tabsSX.htm
tashasdaddy
looks like John and his guys are on the right track.
Gary H NC
Dang it! Now i want a set! The black would look good!
Take any trade ins John??8)8)
KaGee
Dang... you mean I was on to something and you guys didn't know about it?
Go figure! 8)
Boomyal
Gonna take more than some cheap plastic trim tabs to put the Whoop A@# on ol' Boomer. Mine are made from Stainless STEEL. They ain't gonna crack apart and fall off after two seasons.
....sides, those things won't hold a candle to my shiney, like new, Holley 4 holer.;)
Jdeagro
iboats.com Partner
Well, I was going to let this go, but our buddy, Boomyal, forced me into this.
First, I would be nut's to bring out a product that would detract from what I feel is a good reputation.
Ain't nuts yet!
Second, there are many reasons for the plastic ( high density CO Polymer with no fillers). Number one is that Stainless cost are continuing to go up, and they are now twice the cost of two years ago.
Also, the installation is much easier, and faster with the deployment angle and actuator alignment built into the design.
Then, the maintenance and need for anodes in salt water is eliminated.
Also, the strength and durability is excellent without increasing cost.
To address the issue of "cheap plastics" we molded and tested the product with three different materials before we settled on the best for this application. Once the decision was made, we set up a "destructive cycle test" to determine the point of potential failure.
This was the criteria and method for the test:
1) Mount the assembled set to a fixture and a continuously rotating lever arm.
2) Align the arm to contact the plate two inches off center to create side loads which would torque the plate hinges and actuator end fittings (not a situation that would be found in normal usage).
3) Rotate the plate to compress the actuator 1.25" per stroke. The approximate distance require to bring the plate to horizontal in normal usage.
4) set the cycle time to (approximately) once every second (65 cycles per minute).
5) Install a 80 Lb. actuator in the highest pressure setting in order to create the maximum stress possible.
6) Run until failure occurred.
Results: after 48,812 cycles (12 hours of continuos operation) the Actuator "snap and lock pin" distorted at the transom bracket end, but did not break. Water cooling was required to keep the actuator below 210 degrees. No other physical damage was noted.
Prior to production the transom bracket tool was modified slightly to increase the load bearing surface.
The speed of test (16.25 times normal) created stresses and heat which would never be seen in actual use, however if this were translated into actual hour of operation it would be the equivalent of more than four years of starting and stopping the boat four times per minute.
The reason for loading the plate off center was to simulate stresses that may be caused by fork lifts during rack storage.
We are very comfortable with the design.
By the way, Minn Kota's new trim tabs are glass filled nylon.
Tail_Gunner
8) See what ya started Boom ................there light & tight with the need to control your speed, so here come's a cup of whoop A#$ headed your way...........
Psssst John how's about a sponser here..........:devil:
KaGee
John,
My REGAL is technically 20.5 feet w/175HP I/O. (see "MY BOAT PICS")
Am I pushing it with the SX or would you rather see me with 1290-80 original ST?
mailman2
Are there any rebates with these, like the original smart tabs?
mailman2
Could not find the SX"S on Iboats. Maybe I'M not in the right section, any help?
KaGee
They're brand new... don't think IBoats has them listed yet. You can call them Toll-Free and ask though.
Jdeagro
iboats.com Partner
KaGee;
We will begin shipping this week. Iboats has them on order but they will not show anything they can not ship. You should see them up soon.
Your boat is no problem.
mailman2;
No rebates, the SX series is much lower than the stainless version.
tommays
SS is out of control because of the cost of nickel I just bought a bar of 1/2 X 2-1/2 to make a new mixer prop
It was about 140 dollars last week it was up to 300 dollars for a 12' bar with a nasty mill finish :devil:
Tommays
KaGee
Same here. Thanks much John.
Look forward to becoming a Guinea Pig! 8)
Gary H NC
I think i'll keep my shiney stainless steel tabs.I really do like the adjustment holes on the new ones.It would make it easy to set both tabs at the exact settings.Also the new ones would be easy on the legs when you catch one climbing up the swim platform.
The steel ones really hurt:%
Tail_Gunner
Ok so no corprate sponser's huh, do you have any ideal how many corporation's would envy having Boom's underwear hanging from there corprate mantle..........Geeesh.....:love:
This is a once in a life time oppurtunity ...........kinda like the ground floor of Google........o:)
Jdeagro
iboats.com Partner
Tail Gunner;
I think you will be pleased with the price when iboats gets them up on the site. I appreciate your support. Please understand that we are not a large company, just a few guy's trying to do their best at what we do.
Again Thank you!
