rebuild
imported_basshog
What are the required seal kits for rebuilding a 1995 johnson 200 w/ 20" shaft (lower unit only)?
dreamchaser
Re: rebuild
hey bh......brp has a listin for ur seal kit .check it out ......dont know bout the double or single seal thingie .im sure the gurus will chirp up good luck
emdsapmgr
Re: rebuild
Both the early prod double seal and late production single seal kits supercede to 5006373. This is a master seal kit and has seals for many lowers. You will have a lot of parts left over.. Around $80.
