Lubosleftboot
- Feb 26, 2006
- 208
My friend has just brought one of these engines round to me as he couldn,t get it going and lost interest in it.
He thought the engine was seized but when I stripped off the rope start assembly it had fallen apart and the centre nut on the starter assembly was jammed against the crown nut.With this problem solved I attempted to start the motor.It did start but was awfully smokey and kept cutting out.
I removed the plugs and they were fouled with an oily brown substance.I first I thought of water ingression but emulsified oil is usually a light brownish colour and this is darker.Also there is a very strong pee stream and water exiting via the exhaust as there should be I do not know if a blown headgasket would effect the strength of the pee stream.
I next checked the carb and upon its removal I found a lot of petrol sitting in the reed valve housing..something like a carb bowl full...
I have noticed this motor has a choking assembly that seems to deliver a direct jet of fuel straight into the engine via a small spicket on the venturi...my question is...How would the petrol charge be metered and if the petrol charge was just continual then surely the engine would always flood....how would I cure this?
Also would it be possible to fit an older traditional carburator with a butterfly choke assembly?
Once again thanks for any advice as this is the best boating site on the web by a country mile...
LLB
LLB
