Installing bellows without bellows expander tool?
MN86_4winns
Is it difficult to install new bellows without the bellows expander tool?
Don S
Re: Installing bellows without bellows expander tool?
What bellows? What Drive?
If you are talking about a Merc Alpha exhaust bellows, it's a PITA, if you can get it done at all.
Haut Medoc
The u joint bellows is very doable on a Merc. without the tool.....
The exhaust is impossible without it like Don S says.......:)
DHPMARINE
Has anyone ever wondered WHY Mercruiser makes it that way? OMC Cobra's were not easy,but the bellows replacement was a snap.
DHP
Haut Medoc
I'll bite.....
Why is the exhaust bellow oval?.....:}
hoot
i read this tip somewhere and i did it when i replaced mine. attach one end of the exhaust bellows and let it sit overnite. it will take an oval shape. then remove it and turn it around. it makes it easier to install both ends.
Or just convert it to the Exhaust Tube................................:love:
180shabah
Bondo - You have brought up the exhaust tube in the past. What is involved in the conversion and what are the advantages/disadvantages.
The Tube Conversion involves Ripping the old Bellows,+ it's clamps off,+ Installing the Tube......
The Tube attaches to the Transom side,+ is a "Glove Fit" into the Outdrive side........
It takes Longer to remove the Bellows than to Install the Tube.......
I Don't Know of Any Disadvantages...................
180shabah
If it is all "good" why don't more people do it?
MN86_4winns
I just need to replace the u-joint bellow on a alpha one.
Don S
No such thing as a ujoint bellows expander for an Alpha One.
There is a tool to reinstall the exhaust bellows when reinstalling the bellhousing. or you could use the tube as mentioned above.
Then there is the REAL OEM service manual for an Alpha drive. Here's a link to the free online one.
http://www.boatfix.com/merc/Servmanl/6/6covr3.pdf
180shabah
get the full bellows kit and replace everything while you have it apart. You will appreciate later.
Haut Medoc
& your shift cable as well.....
They tend to have approximately the same life expectancy......
& you are all ready that far into it not to......;)
MN86_4winns
Thanks for the advice.... I will replace all the bellows and shift cable. I just not looking forward to replacing the exhaust bellow.
I/O WALDO
How Important is that merc.exhaust bellows anyway??
Don S
The exhaust bellows directs the exhaust thru the drive and out thru the hub of the prop.
If the exhaust bellows was missing completely, the boat would still run just fine, but your drive will constantly be covered with exhaust and it will be noisier. To a lesser degree, the same thing will happen when using the exhaust tube instead of the bellows.
MN86_4winns
Don, On your exhaust tube you are just connected the transom side and having the other end of the tube just hang free in the water?
Don S
First off, I own a Volvo DP not a Mercruiser ;)
Open the document below and read pages 4A-21 thru 4A-23. I think you will then understand the tube vs.bellows thing a little more.
It's 815KB, so may take a while to load depending on your connection speed.
http://www.boatfix.com/merc/Servmanl/6/6A4R3.PDF
hoot
as to why some don't replace bellows with tube, when i did mine, the dealer had the bellows in stock and not the tube. he could order the tube, and it was more expensive than the bellows. i didn't want to wait.
