anyone with a 460 short block 4 sale?
just looking at my engine today and it is shot...I need a 460 d1ve with a 2y crank that I can slap my heads on and go. Anybody have one for sale? Thanks
HT32BSX115
Re: anyone with a 460 short block 4 sale?
I have one. It needs a camshaft & lifters... It had 150-165 PSI compression at last check. When I pulled the intake manifold I noticed that it had some flat cam lobes. It ran 4200 at WOT and I thought it was a vacuum leak ot timing....as it turned out it was timing! Valve timing.
If you're interested drop me a personal message.
Cheers,
Rick
JoChek219
are you looking for a 224cid 3.7L 4cyl or an IL6?
Haut Medoc
Yeah, he could use it for a kicker.....:}
No, jochek i am looking for a big block 460 short block eninge...Thanks though for asken.
bruceb58
Are you looking for a 9 HP outboard?
...just kidding.
HT32BSX115
There's always several 460's in the local Craigslist.
You'd need to maybe swap the cam and put brass softplugs in it though.
You cannot rebuild yours?
JoChek219
haha you sure you don't want that 3.7 i don't either
u guys probably wont belive me but I just bought a running 429 cj eninge at a wrecking yard here in nv for $150.00 I have already ordered a rebuild kit for the engine and a nasty cam...OH ya the blower that snaped the crank in my 460 will sit nicely on it as it makes my boat go zoom zoom!!!! I can't wait...The guy at the wrecking yard had no clue to what he had...What a steal huh...So I gues I don't need that 460 anymore!! Thanks guys I will post more as I need info like what the torque order for the head bolts and intake bolts are..Thanks again!
HT32BSX115
That 429 will work great in your Jetboat!
Just make sure you have the right cam for it. Any blown engine for jet pump service requires something other than a automotive cam to run right.
You also may snap the crank on that one too.......the good thing is that there's always a lot of 429/460s sitting around in peoples backyards and wrecking yards!
Good luck,
Rick
