wiring trim - 3 wire on a 50hp johnson
casi77
how would one wire a trim unit? ie. directly hook it up to a 2way switch? do we need to use a relay or saloneoid?? if a relay or salonoid is required, anybody have a wiring diagram? thanks much.
Dhadley
Re: wiring trim - 3 wire on a 50hp johnson
Start from the begining. We assume you have a 3 wire trim motor. Are you simply replacing the trim motor or installing a trim & tilt system on the motor for the first time?
With a 3 wire motor you'll need 1 solenoid or relay. With a 2 wire motor you'll need 2 relays. What do you have now?
You can put a 2 wire motor on a unit that had a 3 wire motor.
The OE service manuals have excellent wiring diagrams.
casi77
i have a trim motor that has 3 wires. one is black, and two other ones i dont remember the colors now.
i like to put a switch somewhere so i can make it go up and down. i already mounted the trim unit on the outboard.. just need to know how to wire it up with a salonoid.
JasonB
What I did, instead of trying to track down the harness for a 30yo outboard, I went to the local auto parts store and picked up a couple $6 Ford style fender mount starter solenoides (one for yup, one for down).The 3 wires on the trim are green, blue black. I hooked the black to ground, green to one solenoid, and blue to the other. Supplied 12 volts to the other post,and set up 2 momentary switches on the dash to fire the solenoids. Works like a champ.
I could draw it out if that would help. Cost less than $20.
Dhadley
For a 3 wire motor you only need 1 solenoid. The solenoid is wired into the up (blue) circuit. The down (green) doesn't need one.
