FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Actually it shouldn`t be if you don`t change the levers on the carbs. It`s a good thing to do once in awhile anyway. It`s not expensive to have a dealer do it if you can find one that still deals in carbed engines.
Thanks for all the info. I have read over the procedure and it is'nt all that bad, just at first glance seemed overwhelming, but then again so do a lot of things on an outboard.
By doing the prodecure, am i basically setting up the carbs to be in sync. with timing movement, or do I need to go through the entire procedure and set idle speeds, timing, timing advance, the whole smear......
