FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
do they make extra thick headgaskets for my motor I believe they will have to shave off the block alot of material so I was wondering if they are available,,,its a 1996 evinrude 200hp ocean pro 200TXEDR thanks also head bolts do you have them here?
I dont know I know the guy said they do sell thicker gaskets just not sure for my motor Im sure the engine shop will have the answer even if it can be done...lot of deep wide pitting on the surface where the head attaches
I don't think you are going to find thicker head gaskets,and doubt double gaskets will last.But WHY are they shaving the block alot.If you heated it that bad,you must have alot of other damage.And who is doing this shaving?
I think you might be getting alot of misinformation from the shop doing the work.
Maybe they are shaving the head,instead?If it is too warped,you replace the head itself,not make it flat again.
I am along with my marine mechanic friend will be breaking the block down tuesday i brought it to him with the heads removed and the decking surface has some 3/4 by 1/2 wide by 1/8th deep pitting in the block this pitting is on the deck surface between the pistons he had mentioned he doubt it could be planned down that much and if it could be that i would need a thicker head gasket to compensate the difference right now it appears the pistons are flush to the deck so anymore material removed it seems that they would then be above the cylinder wall...the block will be going to a reputable builder after we break it down i was just asking some questions beforehand,,,im sure the shop will have the answers next week but im just really curios if i have to start looking for a block or just pick up a reman
If it were me, I would either find another block, or use this one on a core for a reman. You more than likely will not receive full credit for your block.
There is a sleeve that is made to repair the situation your describing.L.A.Sleeve makes a FLANGED sleeve.a machine shop can remove the old steel sleeve,cut down the alum.cyl.casting and replace it with a sleeve that leaves a new surface for gasket seal.
