Pilots question
Firestar
A plane is standing on a runway that can move (some sort of band conveyor). The plane moves in one direction, while the conveyor moves in the opposite direction. This conveyor has a control system that tracks the planes' speed and tunes the speed of the conveyor to be exactly the same (but in opposite direction).
The question is:
Will the plane take off or not? Will it be able to run up and take off?
Re: Pilots question
Planes Don't Care how fast the Ground Speed is,..........
It's all about Air Speed........
Replace your Conveyor with a BIG Fan,+ the plane Could lift Off.........
aspeck
Re: Pilots question
Absolutly not. Need the air flow over the wings to create lift. It is not the speed, but the lift. Speed is only needed to create lift. If the plane is standing still, no lift.
Now if the conveyor belt was propelling the plane forward, the plane would not need to "run up", the conveyor could get it up to speed for take off.
JB
Re: Pilots question
What Bondo said.
Example: A light plane takes off from the deck of a nuke carrier running into a 20 knot breeze at 30 knots. Air speed is 50 knots and the plane rises from a fixed spot on the deck.
In your example you seem to assume that wheel speed cancels air speed. Aircraft care not about wheel speed, they move relative to the air, not the ground.
QC
Re: Pilots question
Yes it will take off. Unless the brakes are set, the plane does not care what speed the conveyor is running, it will still propel itself forward as it's propulsion acts on the surrounding air, not the surface . . . Theoretically the only additional load affecting the equation is that created by the wheel bearings spinning faster than they would normally have to.
QC
Re: Pilots question
Ooops. New mouse with those fliipin' side buttons :| I keep hitting the "back" button by mistake. Should help the post count until I get used to it.
Firestar
Re: Pilots question
d:):^d:)
jtexas
Re: Pilots question
It might take off. it's more likely to hit a barricade or berm or highway or whatever when it runs off the conveyor.
good answer, QC - hey let's try it with the brakes on and see if it burns up the conveyor motor...........
tommays
Re: Pilots question
If the belt is moveing at a matched speed to the PLANE its not going any place :)
the tires might wear out
Tommays
QC
Re: Pilots question
You guys are missing it. Why does the plane care how fast it's wheels are spinning?
crunch
Re: Pilots question
It doesn't.... until they blow and it rips the undercarriage off. Then, if the conveyor is still running at say, 160 MPH, that puppy will take off backwards. :p
tommays
Re: Pilots question
When i run on a treadmill there is just never a breeze :)
Gotta use a fan to move the air
Tommays
QC
Re: Pilots question
tommays,
Mount that fan to your nose and add 100 bhp . . . You still on the treadmill?
jtexas
Re: Pilots question
try this:
1. Position a treadmill with its back against a wall.
2. Put a skateboard on the treadmill. Stand on the skateboard.
3. Turn the treadmill on.
4. Push against the wall with your hands.
As the treadmill accelerates, do you have to push harder to keep from smashing into the wall? If you lean against the wall with your feet on the skateboard, can the treadmill go fast enough to keep you from falling on your arse?
Gravity is holding the aircraft to the moving runway. And friction. It will start to move backwards. If the treadmill is moving the plane backwards at, say 250 knots, its airspeed is -250. To achieve a ground speed of zero would require enough thrust to achieve an air speed of 250. But once it reaches 250 knots relative to the runway, it'll be holding at airspeed of 0, while producing 250 knots worth of thrust. How can it not move forward?
tommays
Re: Pilots question
(This conveyor has a control system that tracks the planes' speed and tunes the speed of the conveyor to be exactly the same (but in opposite direction).
As described the plane will never be moveing and the wings will not have air flow
Tommays
