Steering Wheel
imported_ss moneypit
How do I get my steering wheel straight? Where are the adjustments that i need to make? When it is straight the boat goes hard right. It is not power steering. I have a 2000 javelin with 90hp johnson.
WillyBWright
Re: Steering Wheel
Some steering wheels have three keyways. A different one might get you closer.
There are two basic steering systems (three including hydraulic). Flat racks are rack and pinion. You can set the motor straight, loosen the rack, straighten the wheel, then retighten the rack.
Rotary helms have the cable wrap around a gear. You can unfasten the cable retainer and turn the steering wheel until the cable core disengages, turn the wheel a bit more, then wind the wheel the other way and reanchor the cable. It's a trial & error kind of thing with those.
Re: Steering Wheel
Or,.........
There's the Easy Way,.....
Convert to a SSteel Destroyer style Wheel,.....
That way there's No Up or Down or Side to get Aligned.......
If you have near Equal turns to each side,.....Your wasting your Time over Nothing........
