Brice Zachow
- Jan 2, 2007
- 5
I have a 1999 Mercury 2cycle outboard motor with 4 carburators. This motor runs great as long as it is perfectly level. If the motor is trimmed either up or down it starts loading up and running rough. If I run the motor at planeing speeds, and then return to wakeless speed, it will run rough even with the motor trimmed perfectly level for a few minutes, (like the choke was pulled on a warm engine) until it apparently burns off the excess gas, and then it runs great again as long as the motor trim is kept level. I pulled the carburators and checked the float levels, and they were all at the specified 7/16" that the manual recomended. Instead of a choke, this engine used a system that floods raw gas into the crankcase when you push in on the key, but it seems to be working perfectly. Any suggestions would be greatly appreciated.
