mstone1968
Thread starter- Joined
- Mar 1, 2005
- 60
Hello Everyone,
Can anyone please help me with Power Tilt /Trim not working properly. I checked and made sure the battery is fully charged and all wires are hooked up properly. When you press the switch, you can hear the motor running but it doesn't move the Motor up or down. After a couple of seconds, the motor stops making a sound and pressing the button doesn't do anything at all. If you let it set a few seconds and try again, It's the same outcome. If you press the button and have someone manually lifting the motor, sometimes it will start to lift motor for a short period. Would anyone have any ideas on where to start diagnosing the problem. I don't know much at all about the mechanics of power tilt/trim. Could the cylinders be low on fluid or something like that? Please forgive me if this is a dumb question. Thanks for any advise.
