freddyray21
- Jun 10, 2006
- 2,460
Near as I can tell the reason this one quit working is that the cork float is hanging up in the bowl. I rebuilt the carb on it a couple of months ago and it was running fine. Loaned it to my brother in law to use on his sailboat. Pushed a 23 ft sailboat at 4 knots right along. Next time he went to use it wouldn't start. I determined it wasn't getting gas and pulled the carb back off. Pulled the float bowl off and checked the passageways and float valve. Seemed the float valve was sticking a bit and would not drop when the float came down. So, I pulled it out and cleaned the passageway out figuring some dirt got in there. Got is working good and put the float bowl back on and put the carb on the motor. Still no gas. Pulled it off again checked the float valve and it is operating fine. Put is back together and before I put it back on the motor I hooked the fuel line to it and I am not getting any gas to the bowl. Only thing I can figure is the cork float is swollen and sticking in the float bowl not letting it drop to let gas in. So I need a new float. If I have to buy the whole kit to get it that's okay they are pretty cheap anyway.
