ITT Jabsco water pump replacement for 454 mag
murinsky
Hello all
I am repowering this winter. The new engine is a generic marinized GM, not mercruiser. It has been built basically as a 454 mag (7.4l, carb, bravo setup, about 400hp) so I'm basically using a parts guide for that motor to furnish the sea water pump, alternator, and power steering.
For the sea water pump, I do not want to use the decrepit garbage from the old motor but rather a nice brass and stainless jabsco unit.
My retailer lists a jabsco pump #43210-0001 as a direct mercruiser replacement for 46-72774-a32. However, stemtostern.com lists as a 454 mag water pump as 46-807151A12 .
What is the difference here? Mounting brackets? Pulley bolt patterns? Flow? Anything at all? If jabsco makes a water pump for me, what part number is it?
(also i get a sweet discount on jabsco parts from a friend)
THanks,
Mike.
