alfolsee2000
Thread starter- Joined
- Nov 18, 2006
- 5
I recently acquired a 40 hp evinrude. I think it is a 1988 and has been sitting up over a year. It is hard to start, won't ide and won't stay running unless I continually work the choke or pump the bulb. If I put it in gear and rev the rpm's, it seems to run better. Once it stops, the bulb is soft and I have to reprime the bulb to restart it. Where should I start; tank, hose, bulb, rebuild carbs, adjust carbs,fuel pump. I have no fuel leaks. Any help to put me in the right direction, will be appreciated.
