FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
I'm assuming it's 3 cylinder, like a 60 or 70hp, correct? Year and model are gonna help out a lot more, but I think that the 3 cylinders at least some models are prone to running lean on that middle cylinder. But that's a carb issue. If that plug is completely clean, it's probably water. Do you have white smoke out of your exhaust?
Definitely check that compression and see what shape that cylinder is in.
everyone is jumping on the new-looking plug (that indeed sounds like steam cleaning) but is it opposite of what it seems,ie, the problem is 1,3 and not 2.
sorry guys new at this forum you can check my other post also to give you guys more info...sorry tanx for all the help. 78, 70 hp jonhson cuts out when put on F or R please help
You will get your best response by sticking to your first post. You have been given a couple of suggestions and I think if you follow them you will find the problem.
