oil in cooling system
elkman
tonight i got my 1971 volvo AQ170 started finally and ran it for awhile with the muffs on and then proceeded to drain the water from the cooling system and when i opened the one that is the lowest one in the back there was some oil in the water. I know enough to know this is a problem just not sure how big of a problem. cracked block? let me know your thoughts and how i can check this furthur to figure out problem and how serious. thanks for replies.
Scaaty
Re: oil in cooling system
Ya might check it one more time to be sure, but if it comes out with oil again, it would be a tough SOB to figure out where....
Do you have P/Steering,..??.......
If So,..... Your P/S Cooler is Cracked,+ Leaking........
elkman
does this mean my engine is junk?
imported_TheMan
If you have a power steering cooler, as bond-o says, than your water is pulling fluid from the cooler while circulating.
If that is the case, no your engine is not junk. You PS cooler is shot and you need a new one. They are cheap.
D
DJ
Guest
Yep, probably Power Steering, if you have it. Otherwise-head gasket.
Engine junk?, Not necessarily. A head gasket is not that bad of a job.
bruceb58
I thought the power steering cooler was always cooled with raw water.
elkman
I dont beleive it has power steering,(i just aquired this boat) i will check it tonight. also i will run it some more and see if the oil level in the crankcase is going down at the same time it is showing up in the cooling system. if it continues i quess i will check compression on engine before i bother replacing head gasket. It does seem to run quite well. any other thoughts?
elkman
i checked this weekend and i dont have power steering. I also pulled the dip stick and noticed some water in oil on the dipstick. Do you think this is blown head gasket as DWJ mentioned or cracked block. I can afford a new head gasket not sure about cost of replacing the block. Is there any method of checking to make sure before i spend lots of money. Thanks
Drain the cooling system,......
Then Plug it Up,+ Pressure Test It..........
Finding the Leak, will tell you IF you want to Fix it.......
elkman
i called the local boat dealer and asked about getting a pressure check and they said they dont do pressure check and said to bring boat in and they would do a visual and try to determine my problem. Is it possible to do a pressure check myself with an air compressor and if so how do i go about it . thanks
Due to My lack of familiarity with the Volvos, I can't get very specific,........
But,......
Basically, you need to Isolate the Cooling System around the Block with Block-off Plates or Whatever,...Along with a way to Feed Air into it,+ a Gauge to monitor the Pressure,....
Then Pressurize it to about 15/20psi,+ Listen,......
If it's Leaking,.. You'll Hear it......
If it's a Very Slow leak, the Gauge will Tell you.....It Should hold 15psi Indefinitely.....
Oh Ya,..... Drain Everything 1st......
Don S
The AQ170 also has a raw water cooled Oil Cooler that has probably been damaged. Freeze crack or corrosion holes on the tubes would allow oil into the cooling system.
The cooler is that round thing just under the oil filter. Remove it and pressure check it.
