2000 Chevy Silverado 2500 6.0 Codereader reads 4 codes. They are as follows...
P0140 Bank 1 Sensor 2 Sensor CKT no activity
P0 160 Bank 2 Sensor 2 Sensor CKT no activity
P0160 Bank 2 Sensor 2 Sensor CKT no activity
This truck has 4 oxygen sensors. 2 in front of the cats, 2 after the cats. I just replaced the two after the cats( $75 each) with Bosch #15733 universal sensors. wired per instructions. purple to black, tan to grey, 2 whites to 2 dark brown. Erased the codes and all was good till I drove about 10 miles. The S.E.S. light came back on with the same codes. last year I replaced all 4 of them beacuse it had those codes plus the codes for the front ones. I believe they were smoked by a bad fuel pressure regulator which I had to replace at the same time. After replacing all four....the codes for the fronts went away but the existing codes never went away. I rarely drive it, but figured it was time to finally fix it. Fuses are good. What else could it be? Why am I getting 2 of each code? Thanks
