90 mariner help!!!!!!
Jobsite
Hopefully someone my be able to help!!! I am at my whits end with this one. I purchased the engine under the impression that it only needed a switch box, although it had been sitting for two years. I have replaced the switch box, rebuilt the carbs, replaced the fuel pump, and checked the compression. All have checked out Ok. I have even taken it to my dealer to check and set the timing. What esle could it possibly be, it has spark and gas just no power. i will get on plane and run but no power. It is on a 15' Whaler so it should be sick fast, it is only doing 35mph. Sorry for the long post hope someone can help.
Clams Canino
Re: 90 mariner help!!!!!!
Prop pitch correct? Depending on the whaler weight, you may not be too far away from normal.
-W
Jobsite, The fact that you get on plane means that you have quite a bit of power. What is the RPM at WOT? What is the compression of each cylinder?
I guess I do not understand why a motor that pushes a boat at 35MPH is considered to have "no power".
tashasdaddy
is you're trim correct. height of motor on transom. sound like you have a set up problem. if you didn't change the impeller, you're going to have an over heat problem soon.
