Volvo Penta or OMC Cobra Holley Carb Question
WillyBWright
I need to replace an accelerator pump check valve in a 2-barrel Holley carb on a 1999 5.0GL PWTR motor. I cannot find that specific part pictured on the BRP website (the 1998 OMC 5L appears to use the same carb). Part numbers on the carb are as follows...
3858334
75004-1
2208
We ordered a 18-7244 carb kit thru NAPA. It appears to be the correct kit, but doesn't include that check valve. It attaches in the float chamber above the accelerator pump diaphragm which is #5 on their diagram. But this specific part that I need is not pictured. It is brownish red, about dime-size, and attaches with a nipple in the center of it to the float housing. I guess you could call it an umbrella valve.
Any help as to number and source would be most appreciated. :)
bjcsc
Re: Volvo Penta or OMC Cobra Holley Carb Question
Is it the umbrella check valve? Does it look like this?:
Holley Part#26-41. Click here.
WillyBWright
That's the animal. Many Thanks!!! :D
