tmljunkmail
- Oct 21, 2006
- 50
What a great site this is.....great info.
I'm having some issues with my Sea King.
It always starts on the first 1-2 pulls and runs great.
However, after about 3-5 min of running it gets labored and eventually stalls (though seizing might be a better way to describe it). After it stops.....there is a release of smoke which lasts for about 2-10 seconds. (It runs pretty smoke free before that point).
I assume this is because the unit is overheating.
After 5-10 min it will start right back up again without problem.....but then same cycle with stalling.
I'm guessing that this has something to do with the water not pumping though the unit properly.
I do note that what appears to be an exhaust port at the very top of the lower unit (about 3" below the top of the motor unit) does not have any water flowing through it during operation. In some of the posts i read in here it seems like the experts are saying water should be comming out of here....though I'm a little unclear about that.
I triple checked my fuel/oil and I am at 24:1 with the proper marine 2 stroke oil.
I've NEVER worked on a 2 stroke engine before (or really any small engine for that matter) but I am very mechanically oriented and did purchase the manual the other day (which I expect any day now).
Anyone have any ideas?
Does it appear that I have the right idea with the problem?
Is this something that I will be able to deal with on my own?
Thanks in advance for any info you can provide.
