4.3 OMC aftermarket manifolds
Gary H NC
Re: 4.3 OMC aftermarket manifolds
Just wondering why the big price difference between the 2 brands..
I Believe that Oscos are cast in Pennsylvania,.............
And,........ GLMs are Chinese......
I just put a set of GLMs on My motor last spring,.......
I like them.......
Gary H NC
Thanks Bondo. for 300 cheaper i'll try them...winter project maybe..
There is a used set of OEMs on ebay but i'm kinda scared buying used..
KaGee
Don't waste your time unless there is some extenuating circumstances. I bought some used ones and it cost me dearly.
BTW I heard that toe OEM versions were around $800 a piece if yo could find them.
I went with OSCO because it was the only way I could go to replace my rear riser OEMs. But I looked at GLM.
Gary H NC
Thanks KaGee,
The guy that has the oem's on ebay is also listing a whole engine that has milky oil...:^:^
So i'm passing on those manifolds...He also has a 4.3 truck motor for sale that he tried to run in his boat!
Not sure how smart that guy is...LMAO!!
KaGee
Wonder what happened to the GLM "batwing" replacements they advertised two years ago??
tommays
I get a few different parts cast from different foundrys in iron, bronze and alu
And most of the Alu parts we went to CNC out of solid billets because of foundry problems
I have to think that there is a huge core failure rate in the batwing casting
Tommays
tashasdaddy
just note the are not for the VORTEC engines. vortecs, valve overlap will suck water back into the cylinder, with these. believe i fought it for a while.
