Boat turns right
bluediamond46
when i let go of my steering wheel,,the sharply turns to the right! what is wrong and how can i correct this, as it is very dangerious if you dont hold on to the steering wheel tight.:%
ezeke
Re: Boat turns right
Reset the trim tab in the direction of the stress or to starboard in your case - small increments.
R.Johnson
Boat's don't track like land vehicles, You can't let go of the steering wheel, and track in a straight line. Some steering torgue can be over-come with a trim tab adjustment. Motor height, and prop's can also make a difference
ezeke
I stand corrected, Commander.
In most instances, reset the trim tab in the direction of the stress or to starboard in your case - small increments.
This often occurs after the lower unit has been serviced, because the trim tab was not set to the former location.
rickdb1boat
It should not "Turn Sharply" to the right. Wander to the right would be more appropriate. Check the trim tab and adjust the rear of the tab to the right (Yes, to the right) in increments until it's better....
F_R
You don't say what you are running. Steering torque is not uncommon on large motors, even with the trim tab all the way over. Bite the bullet and put in hydraulic steering. It does not cure the harder steering in one direction, but what it does do is hydraulically lock the steering at wherever you stopped turning the wheel so you don't have to maintain a death grip on it.
emdsapmgr
Steering torque. All engines have this-worse with higher hp engines. On some engines- at full trim- the tab has little effect. It may not even be in the water. As mentioned, you won't eliminate the problem, but can mask it by making setup changes: power steering, hydraulic steerming, NFB steering, changing engine height, props, torque tamer tab, etc. What engine/boat?prop are you running? You'll get good ideas from the experts here.
bluediamond46
Petty officer---i am running a ranger 14'4" boat with 50 hp evinrude on it.
F_R
There are several complete new hydraulic steering kits on e-bay right now. Save $
canadian_fisher
Do you have a manual or hydraulic tilt and trim?
If hyraulic, try playing with the trim when WOT.
My 100HP really pulls hard even with trim tab set until the boat gets on plane.
Once on plane, the trim tab is competely out of the water anyways.
CF
ezeke
I am trying to visualize the size and type of propeller that allows the trim tab to be completely out of the water.-?
The only time that the trim tab has not compensated for thrust on my 140 looper, which is a torque monster, was when I had a bent skeg with a Skeggard on it. The local welder fixed that problem in about 20 minutes.
canadian_fisher
ezeke.
Have a look at where your trim tab is in relation to the bottom of your boat (when trimmed up).
My engine sits high on the boat and I only have a little boat and bunch of SS prop left in water at WOT.
Torque tab is useless to my set-up at 45MHP.
It really only comes into play when launching to plane.
Cheers. CF
ezeke
After 64 years I can still see that the trim tab is almost completely behind the propeller, where it has always been. Respectfully, I think that you may not understand the concept.
funpilot
I might be relatively inexperienced, but I've never had trouble adjusting the trim on a boat with the trim tab. Even on fairly large motors I've been able to allieviate my friends' sore arms! I'm with ezeke on this one...
funpilot
bluediamond46
I'm with you guys,,,,,i dont know what your saying but "O.K."
funpilot
canadian_fisher
ezeke.
I stand corrected. For some reason, my brain was confusing the issue.
Disregard my previous rant.
I'll stick with the Electrical / Motor repair issues.
CF
On my 1977 115 rude the trim tab has a hole I think for cooling of the prop hub so my trim tab is always in the water!!
