Hello,
A few months a ago i posted about my TXP. My engine is a Yamaha 200 HPDI, my boat is a Yamarin 6110. With the same adjustments the TXP(14x21) did 45knots at appr. 5100rpm while an original ballistic did 48.5knots at 5400rpm(i'm not completely sure about that latter rpm but it's close). So i bought and installed a manual jack plate, CMC ML-65. I kept the engine at the same height and did a test run with TXP and i reached 46knots at 5200rpm. The AV-plate is about 2cm above bottom. I readjusted engine height up 2.5cm - 1inch(totally 4.5cm above bottom), a new test run revealed no difference to my surprise, almost exactly the same 46knots - 5200rpm. This is with GPS and OEM tach. I also have a pressure gauge installed. How come that the engine can't turn the prop faster when one inch of the engine is out of the water?
When i run at WOT i can still trim the engine out of the scale of the OEM trim gauge, but the prop has started to throw some water up in the air and i wonder if raising the engine further would do any good.
This makes me wonder if the TXP is not suitable for my hull after all. Maybe the Turbo 1 would be a better choice or perhaps Mirage Plus or Laser II? Or would a pitch drop from 21 to 19-20 make any improvement?
Opinions, ideas greatly appreciated. If i have forgotten any details, let me know.
A picture of my boat: http://personal.inet.fi/surf/masa/myboat.jpg
and of the installed jack plate: http://personal.inet.fi/surf/masa/jackplate.jpg
/Mattias
/Mattias
