351 engine only runs at 30 degrees BTDC
qaztwo
Re: 351 engine only runs at 30 degrees BTDC
first with the engine running I would pull a plug wire off one by one and see if that effects the engine at all. One time when changing my dist mixed up some of the plug wires same effect.
bluesdude
I can turn the rotor ccw but not at all cw. I took off the dist plate and the weights and springs looked good.
