Johnson Sea Horse
Jerome
I picked up a 2cyl. Johnson Sea Horse fishing motor at a yard sale and would like to know what year it is and what horse power so I can try and get a manual for it.
The serial is 67330 Mod H.D 25. I Would like to thank anyone that can help me. Jerome
JB
Re: Johnson Sea Horse
Howdy, Jerome.
The HD-25 was made from 1946 through 1948.
It is 2.5Hp, uses Champion J8C plugs gapped at .030".
Set the points in the magnetos at .020".
Good luck. :)
Jerome
Thank you JB You just Helped a Canadian The motor runs fine, I just cleaned the carb. put a bit of gas in the cyl. and it fired up first pull. Jerome
Scaaty
Make sure you use 24 to 1 on the oil mix!
(JB, yer slipping here a bit, or your not ready to start an oil argument? 8) HA!
JB
Ooops! Ya got me, Scaaty. 8)
Scaaty
JB, after 25000+ correct post, well, we will let this one slide! Congrats on quite a milestone by the way!!!
