lower unit filling, 1976 2 hp johnson
mark s
Is there only one screw for the lower unit on a 2 hp motor? I have filled others and always taken out 2 screws... one upper, one lower. I figure it's possible that there's so little oil going in that I could do it with one.
Thank you,
mark s
rickdb1boat
Re: lower unit filling, 1976 2 hp johnson
I would get one of these and fill it slowly until it comes out the hole. Replace the filler screw washer/seal...
images
Paul Moir
I'm sure rickdb1boat ment to mention, you fill it while the engine is lying on it's side with the plug facing up.
It takes on about 1.25 oz!
rickdb1boat
Thanks for the follow-up, Paul.....
mark s
Thank you very much. I appreciate the time you both took to answer.
Mark
