FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
20 amp sounds right i think 5 amp w/b too low, i will get one from the auto parts and in stall, i had the big connector diconnected and i was cleaning one of the pins with a screw driver and it sparked, dumb move! that is how i blew the fuse!
Yes you can get the fuses , I just like the fact I can get the atm fuses at just about any gas station, convenience store, etc. etc. Also the ruber holder is more or less water tight . And since I use the atm fuses in my fuse panel for everything on my boat . I dont need two different type fuses. They are also relatively indestructible, unlike the glass ones. But, of course everyone has an opinion, thats just mine.
I check the output it is running a bit high14. 90 volts but it has been doing that all year long, replaced the voltage regulator 2 years ago with a new one it is water cooled located uder flywheel !
DWJ, Thanks for the reply. The only reason I suggested , the change, is . Ive had problems , especially , in the older fuse panels , that take the glass fuses .
The clips that hold the fuses get weak , loose etc. Resulting in a poor connection.
But mainly , the availability of the glass type.
Much harder to find, when compared to the atm fuses.
