Re: compression tester
An engine has to suck in a fuel/air mixture, compress it (squeeze it) and then at the proper time ignite it to create the explosion that forces the piston down, turning the crank which spins the propl Compression occurs when the piston is on its up stroke. At this point its working just like an air compressor. With the spark plug removed, you spin the engine over, and read the pressure developed in the cylinder with a -- you guessed it -- a compressioni tester. On most engines all cylinder will rarely read exactly the same but they should be close. Within 5 - 10% will be ok. As for the actual reading, most manufacturers don't even publish compression readings. But if you have 90 PSI or more the engine can be assumed to be ok internally. That does not mean the electrical and fuel systems are ok. It is advised that you hear the engine run and if possible do an on-water test run.
