1988 Merc 60 3cyl, bad wires, what are they for?
newuserguy
[attachment=img=PICT0004.JPG] Hi all, I bought this 88 Merc 60hp, there are two wires, they look as if they carried too much elec. or were shorted. What do they go to? they are the one's in the upper l. corner near the hose and they disappear under the flywheel. Could they be to the starter (notice the fried drive gear)? Also, no tilt/trim
newuserguy
Re: 1988 Merc 60 3cyl, bad wires, what are they for?
Darn it, my picture did not show up. I'll try to post it again. Thanks
andy6374
What color are they? A little more descprition too, a pic would be great
newuserguy
Andy, Thanks for responding. I can't tell the color, all insulation is burnt off. Do the pictures help. Thanks.
ricksrster
Are they the two yellow wires connected to the rectifier? There will be a grey wire connected with one of the yellows. The red is your 12+ DC. The yellow wires come from the stator.
newuserguy
Rick, I am going to retake the photos and poit out the wires with a pencil. Thanks everyone for the help. Back soon.
ricksrster
The two yellow wires on top at the square thing (rectifer ) by your finger are the AC wires from the stator to charge your battery. The grey wire connected with one of the yellows goes to your tach.The red wire is DC +. It connects to your starter solonoid.
The switch box wires are as follows:
Left side, top to bottom:
Violet, white, brown. These go your trigger under the flywheel.
Top, left toright:
White /black from the trigger, Black/yellow from the kill switch and key off, blue, red. The blue and re are from the stator.
right side, top to bottom:
Green/red to coil- cyl 3, green/white to coil- cyl 2, green to coil-cyl1.
