60hp evinrude exhaust cover gasket
mopar1970
I have a 1983 60hp evinrude 2cyl that I have water getting in the bottom cyl I told it is probably the exhaust cover gasket as I have good compression. My question is, is it possible to change the gaskets with the powerhead on the motor becouse it looks like the bottom bolts will not come all the way out or is there a way to drop the lower cover????
Any input apperciated
Thanks,
Chris
Silvertip
Re: 60hp evinrude exhaust cover gasket
The lower cover can be removed for access.
mopar1970
So is there just some srews from undernieth that hold that on?
Thanks,
Chris
F_R
Note that the lower cover is in two pieces. Remove the couple of screws that hold the front part and remove it. After that, the rear part is held by 4 screws coming down from above, in the lower pan.
F_R
But, I'm not too sure that will get you the access you are looking for. I'm thinking the powerhead has to come off, but stand to be corrected.
