Capt. Crunch
Thread starter- Joined
- Sep 1, 2006
- 50
Hi, I'm new here and love what I've read so far. Also done some searches and found very relevant stuff... just a little overwhelmed.
I have a V6 150 (guessing 1978-79 based on the serial) that came as a "repower in progress" on the 2nd boat I picked up. Got the manual today and got it all wired up and started. Here's the problem- the peeing is somewhat sporadic. It seems to be sporadic at various rpm's, not just idle. When it stops, it looks as though it surges or "builds up" to a point where it will shoot out and also come out the exhaust relief ports below the pee hole. After that it might take anywhere from 1 - 5 seconds to build back up. I'm afraid to run it too long to get any more info and I'm also hesitant to take the rpm's up too high seeing how I'm just running it in the driveway on the garden hose. Also seeing some sporadic drips from the relief valve hole.
Thermostat? Poppet? Diaphragm? Impeller? The motor looks to be well taken care of but the hose going to the pee hole was disconnected and I removed some inhabitants from the line. Maybe I didn't get it all out?
Any help with a plan of attack would be appreciated... Thanks.
