Long story shorter: Got an ebay engine, took it to local authorized repair guys. They said: replace lower lube, water pump impeller, rebuild carb. I said 'do it.' Picked it up, and they said: 'no need to rebuild carb, good compression, fire.' I was pleased that I saved a C-note.
Took my engine to the boat (26' Sailboat, 6000 lbs), got fresh fuel and oil (50:1) new tank, fired it up.
My engine started after 2 pulls, then quit. I had the choke out, and the temp was about 95. I disenaged the choke, and it ran fine after that. After a short warm up, the twist throttle control was not allowing a smooth idle.
After messing with the slow speed idle adj, it was a bit smoother, but gave some serious misses every now and then.
After five minutes of out of gear running, and some amount of consternation, it shifted easily, and we left the slip.
OK, now comes the WOT issue. After getting clear of the slip, the grip was advanced so that the engine was running about half. When I twisted more, the rpm's did not increase. After a few minutes, while the twist was full 'FAST,' the engine caught a new attitude, and the revs jumped up.
This behaviour(?) repeated over 2 gallons, and about 15 miles of observation. I felt as if the revs never really got up to a rate that would be considered 'redline.'
Questions: How may I measure the rpms on this engine?
Could the prop be an issue?
I looked under the cowling, and found a screw that rode on a cam thingy that affected the actual throttle position, there was room for adjustment.
I want to express my appreciation for everyone that has made this forum possible.
