JoeMan
- Jun 29, 2006
- 322
PLEASE SEE SEVERAL POSTS BELOW FOR 9/11/2006 NEW UPDATE AND NEW QUESTION - LOOK FOR ALL CAPS SAYING "UPDATE". Thanks!
My '95 Merc 60 outboard has been idling sort of rough, shaking a bit. I made adjustments on the upper 2 carbs to make sure they're running optimally. When I made adjustments on carb #3 (bottom one), there is NO response from the engine whether the mixture screw is turned in all the way, part way out, or all the way out. No change at all. Can you tell me what might be going on, anything else I can check, does it sound like a carb re-build? And if I do need a re-build, where do you get your carb kits from, and how to know what to get?
