MASTER Brian
Thread starter- Joined
- Mar 26, 2006
- 738
I was getting ready to perform a sync & link and found via my (homemaid) spark tester with gap set at 7/16" that I didn't have spark on 1, 3 & 5 cylinders. I hooked a plug to #1 and it sparked, but I couldn't get it to spark on the tester. I didn't try the other 2 cylinders, figured I'd find the same and was running short on time.
I'm assuming this is a power pack issue, which I plan to test, what else might cause this?
I should mention, I have had some issues with tach being intermittent and was told that was/is an indication that a certain electrical part was going out. Thought it was the rectifier.
I should also mention last time out I had a miss, that felt like a fouled plug. I pulled all plugs to clean and found 2 plugs that were bent and breaking at the porcelain. Not sure if they were broke prior or broke when pulled this time.
Were should I start looking for my issue??
