murcruiser i/o steering upgrade
cody1bud
is there some way i can up grade my 75 merc 165 to power steering. i would love it if my girlfriend was strong enough to drive this boat
Haut Medoc
Re: murcruiser i/o steering upgrade
Probably, but it will not be cheap.......
You would almost need a donor boat....
Have you tried adjusting the trim tab on the drive?
It can make quite a difference ;).......JK
Welcome to iboats, BTW
Don S
JK is probably right about needing to adjust the trim tab on the drive to make the steering easier, but if you do want something like power steering have a look at hydraulic steering instead of power steering. You will have no feedback from the drive, easy to steer and turn at all speeds, and easy to install.
http://ww2.seastarsteering.com/STERNDRIVE/stern.htm
When this link opens, you will have to click on "Remove this frame" in the black area above the site.
It might just need a Grease Job,.... Or a New Steering Cable........
Have you Inspected it to determine Where it's tight,..??......
