Motor idled well on flusher at home. First time on water, motor started and idled fine. After warming up I ran for 100yds. and motor died. It would start on second pull after one pull on full choke but wouldn't idle so I could not put it in gear. Now it won't idle on flusher. New fuel tank with fresh, clean gas.
I know from archives that the usual answer is to rebuild the carb. Why would this happen? Why are outboard motors so sensitive. None of the other 2 cycle engines I own give the problems everyone seems to have with outboard motors.
Assuming something got in idle needle seat, would it be possible to remove the idle adjustment needle and flush the seat?
Any help will be appreciated.
tylertown
tylertown
