replaced prop-hub
razzor
1992 mercury, 75 horse, serial # 0d165408
Iv replaced the prop-hub and gained a little more throttle but still not running like a 75 horse motor.
Idles great and starts off great but as I increase throttle it starts to bog down and won't open up, It really wants to but it just can't quite do it,
Something feels to tight or won't come loose, I don't know what it is, goes into gears just fine, never stalls out,
What am I missing? wrong mix? bad plugs?adjust the carbs???????? The self oiling pump is out so Im just mixing the gas and oil in the tank.
Thanks in advance, Razzor
timmathis
Re: replaced prop-hub
Over proped?
What are you mixing at 50:1 ?
Try pumping bulb and seeif it helps at WOT.
razzor
timmathis said:
Over proped?
Will do tommorow, Thanks.
razzor
timmathis said:
Over proped?
Thanks Tim,
Prop is correct, fuel mix is good, If pumping the bulb helps at wot what does that tell me?
thanks, razzor
razzor
timmathis said:
That will tell you that fuel pump is bad.
"Right on brother, Right on" I will start that process as soon as the sun comes up.
I feel like I,m getting down to the short rows now, Thanks alot everybody. Razzor
