tailering and boat cover
nightvision
Hi all,
I have never tailer a boat with a full cover on the boat before (bow to stern). On long distance travel, would I save some gas by putting on the cover? Any downside to trailering with a full cover on that I should be aware off. Thanks.
bruceb58
Re: tailering and boat cover
Depends. Was your cover designed with towing in mind? Does it have reinforcemnets over all sharp edges. How are the tie downs? Are they placed often enough so that there will be no flapping?
JB
Yes, nightvision, you will save gas, assuming the cover fits well.
When I towed RED SKY without a cover (about 400 miles) I got 13.5mpg.
When I towed her to Canada and back (about 3,000 miles) with a full cover I got 15-16mpg. That is near a 20% increase in mileage.
tommays
When i Towed with a GM van i was able to use a cover without problem :)
I switched to a GM pickup with a bed cover and the way the air flow hits the boat NOW it beats the cover to death :(
Tommays
Silvertip
Tommays is right. I tow thousands of miles each year with two vehicles. A van and a pickup with a glass lid. I always tow with the cover (made it myself) because it does reduce turbulence IF it is a fitted cover. Airflow off the back of the vehicle (van) makes the cover balloon outward or it can cause the cover to be blown inward (truck). The van is now retired because of this. My cover requires no tie downs except for the nose bra as can be seen in the picture. Keep air from getting under the cover and you don't need a bunch of straps. It also needs to fit tightly as any flapping will beat the cover to shreds. Removing the windshield (if practical) also custs wind resistance. Here's my cover.
bruceb58
I also make boat covers. Just finished off a full one for a 26' Formula. It would probably be fine for towing but I prefer a snap in towing cover (tonneau cover) for towing because there is lees wind resistance on it. Here is a picture of a towing cover that I made:
DaveM
Another aspect of a flapping cover is that it tends to beat the snot out of the gelcoat.
