rickd20006
Thread starter- Joined
- Aug 6, 2006
- 49
Hey all
Just did carb kits on my 83 70hp Johnson 3 cyl.
Didn't use everything just the float and needle assembly.
And some washers. Didn't need the plugs not leaking from that location.
Can someone verify that these carbs don't have any kind of adjusting screws. All I see is a few Orifice plugs low and high speed. I thought there would be something to adjust for air fuel mixture , but I didn't see anything.
I was told by a service department that as far as setting the float I should invert the carb and make sure the float sits level. is this right? Because I am still leaking fuel out the front of the carbs when I bring the motor up. I do have a manual as well but it doesn't mention anything about setting screw. But it does mention the 1984 model has a different carb that has this adjustment. Mine is an 83.Guess I'm just looking for clarification. I would hate to think that after all that I will still stall during slow throttle up.
Thanks in advance
Rick
Thanks in advance
Rick
