OMC control box question.
deerhound
I have a single lever OMC control box, my evinrude 40hp 1984 would not go into reverse, after advise from you guys I have finally adjusted the cable to allow it to engage, (not tried in water yet), my question is what is the significance of the detent when the lever is moved from neutral to either forward or reverse positions? should the engine be in gear at this point? thank you for any help. JBD
Mark42
Re: OMC control box question.
Right. The detent means the transmission should be in gear, either forward or reverse. And the throttle should not start to move until the lever is moved PAST the detent point.
Be careful when shifting with the motor off because without the motor running, the dogs in the lower unit may not mate up properly. Simply turning the prop by hand when shifting into gear will prevent that. (this often requires an arm span of 12 foot or more or the help of a friend)
Silvertip
Take the cowl off the engine and watch the two cables as you move the lever. Remember, you have one lever doing two things (throttle and shift). As you move the lever forward or backward from neutral, one cable must first shift the lower unit into gear (forward or reverse). As you continue to move the lever, the other cable begins to move which applies throttle.
deerhound
Very good information Gentlemen, I have adjusted cable very slightly to get reverse, but both forward and reverse are fully in gear at detent and throttle does not pick-up untill past this position, will update after trial in water this week? thank you agin JBD
KYHunter2
Also , if you don't know.
The worst thing you can do is e e e e a se it into gear.
You need to more or less , snap it into gear, for lack of a better description.
This is both for fwd. and revrs.
Any other way , can lead to , gear case repairs/ worn clutch dog .
Just in case you weren't aware.
Good- Luck,
KYHunter
