neil.westermark
- Jul 24, 2006
- 4
Hi Guys
I have an evinrude 70hp 1978 engine. The engine hasn't run for 2 years. decided will take the boat out this summer so I changed the fuel tank and spark plugs run the engine at home had a few problem starting it but with some carb cleaner it eventually run fine.
however took the boat out in the water today started fine but as soon as you put the boat into gear it stalls the engine I have tried both forward and reverse but still no luck. Warmed the engine for a while also tried revving it manually at the engine again the engine revs fine but as soon as it goes into gear it stalls. Please help guys really want to take the boat out before good weather stops
Hi Guys
