Captain Caveman
Thread starter- Joined
- Mar 1, 2005
- 1,059
Only the top cylinder is running. I know this because I replaced both plugs and the bottom one is still spotless after running the motor. Also, if you remove the plug boot while the motor is running there is no change.
I bought and installed a new ignition coil, but that didn't solve the problem. What could be the issue? I've read in a few threads that it could be the power pack. That may be true but I don't want to waste another $50 just to find out that it was something else.
How can I determine the source of the problem? Is replacing the powerpack the next logical step?
Thanks in advance.
Thanks in advance.
