Hesitation Question
timmathis
Re: Hesitation Question
He said he had a hole in his bulb. So it for sure has to be replaced! And could lead to his problem..
jaymasta
replaced my bulb and most of the fuel lines today, made no difereance at all same thing, get it up to 2000rpm, and it stutters and will die if i give it more gas, give the bulb a couple squeezes and it goes, also today I tried pressing the choke button as it was stuttering around 2000rpm, that got me right up on plane in no time at all.....does this again lead to rebuiling the carb or other problems, thanks again for your help guys
jaymasta
ok so Iam going to rebuild the carbs, probobly after summer though, what do you guys think of this, I'll be doing quite a bit of fishing and tubing etc on the lake, will running with the carbs working as they are cause any damage, or will or can they just give up on me at any time, or should i be ok for 2 months?
